ACL allow port range - ASA 5505
Feb 19th, 2009
Is there a command to allow a range of ports or all ports to pass through? I can allow individual ports with an eq statement (eq smtp, eq 3389, etc.), but I need to allow a wide range (or all)from one specific IP address through to one specific server. Thanks.
Overall Rating: 5 (1 ratings)
philiechang Thu, 02/19/2009 - 15:44
yes, you can use the range command.
eg:
access-list dmz_access_in extended permit tcp host WEB host EXT-WEB range 8500 9000
jdrose_2 Fri, 02/20/2009 - 05:52
Thanks! Just curious - is there a command to allow all ports or do you just need to expand the range to incluse all?
acomiskey Fri, 02/20/2009 - 09:43
  • Green, 3000 points or more
For all tcp ports just do...
or all udp ports...
access-list dmz_access_in extended permit udp host WEB host EXT-WEB
or both
access-list dmz_access_in extended permit ip host WEB host EXT-WEB
