Problems with Cisco 805 routers
Feb 19th, 2009
I have two cisco router 805 while connectin them via serial interface its working but with time out so here is simpli configuration :
outer#sh run
Building configuration...
Current configuration : 529 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$F.fX$51xNeA9CxliJ59flb6CUo.
no aaa new-model
ip subnet-zero
interface Ethernet0
ip address 192.168.50.1 255.255.255.0
interface Serial0
ip address 192.168.20.45 255.255.255.252
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.20.46
ip http server
line con 0
stopbits 1
line vty 0 4
password admin
login
end
I tried with ppp but it was same
here is the ping timeout
Router#ping 192.168.20.46 repeat 1000
Sending 1000, 100-byte ICMP Echos to 192.168.20.46, timeout is 2 seconds:
so can anyone hlp to resolve this problem I tried new ios but it doesn;yt help me
thanks
spremkumar Fri, 02/20/2009 - 13:19
Have you checked for the bandwidth utilization on the serial ports ?
Do check the interface utilisation when you do the ping and also check for any fault with the cable.
As far as i know the serial port in Cisco 805 supports a bandwidth of 512Kbps only.
regds
dreams_as_money Sat, 02/21/2009 - 01:11
HI thanks for U reply
but I never heard it works with 512 kb
How I can check interface utilization plzz explain me
and I tried with 512 kb speed but there was no effect
spremkumar Mon, 02/23/2009 - 07:24
You can check the same using show interface serial x command, the bandwidth limitation is there by default.
You can check out for the data sheet on Cisco 805 routers though its a smart serial port it supports only 512K.
regds
dreams_as_money Mon, 02/23/2009 - 21:53
Thank U
But if it work with 512
and why it works with 2 mb
I am ve kin to know why?
dreams_as_money Tue, 02/24/2009 - 04:13
I tried it with 128kb it work good but while checking with 512 or more bandwidth it works with timeout
