Attachments with no Extensions
Feb 19th, 2009
We have a requirement that any emails to a specific domain with certain attachments will be required to be blocked. The problem is, most of these attachments have no file extension. Anyone have a creative way to include this into an attachment rule? I also need to add pdf, doc, xls, etc.
kyerramr Fri, 02/20/2009 - 08:13
Hi madhour,
Could you provide with some examples as to what these attachments are and their file types. Your second part of the question should be achieved through content or message filters.
-Kishore
jwiegert1 Fri, 02/20/2009 - 15:27
They are pretty much text files that were created from our iSeries. They just don't have a file extension such as file2009.txt. They are just file2009. I have a rule to catch everything else, but just don't know how to catch non-extension files.
staylor_ironport Fri, 02/20/2009 - 15:46
Would it be possible to create a filter looking at the mimetype instead of filename. at least this way the filter will always recognize an attachment with or without the extension on the end. :D
Donald Nash Mon, 02/23/2009 - 18:46
Hmmm, you may be able to use a regular expression:
if (attachment-filename == "^[^.]+$")
That will match any filename that does not contain a dot.
if (attachment-filename == "^[^.]+\.$")
That will match any filename that ends with a dot.
jwiegert1 Mon, 02/23/2009 - 19:05
I took advise from a previous post and used attachment-mimetype == "application/*"
Donald Nash Mon, 02/23/2009 - 19:22
Yes, I saw that after I posted, since your note to that effect ended up in a separate topic.
