2 serial links load balancing
Feb 20th, 2009
I have 2 2621 Routers and these two were connected via 2 serial links (2Mbps per link). I want to know is that how can I share a traffic between those two so it can sum up a total of 4Mbps. What is the best way to configure this ? Hoping for your prompt response.
Giuseppe Larosa Fri, 02/20/2009 - 00:38
Hello Jaime,
you can:
use L3 load balancing features having the two links as equal cost paths in the routing protocol in use or using static routes.
But this cannot guarantee a fair load sharing on the links
there are bundling options :
PPP multilink
FR multilink FRF.16.1
I would suggest PPP multilink
Unfortunately I cannot search in CCO it is not working
Hope to help
