Hello Ashish,
your template looks like correct
you have an ip acl applied inbound to unprotected interface
you have then an inspect applied inbound on the protected interface.
Actually you have two protected interfaces one for data and one for voice.
This can be the part that needs to be tested.
However, I see that multiple interfaces are supported
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_cfg_content_ac_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1002571
Hope to help
Giuseppe
