Re: Can't get DHCP IP for WLAN connection ....
Feb 20th, 2009
[1] I have a problem here I cannot seem to get a DHCP IP for my wireless connection. I have tested the DHCP scope on my wired network and it works, so looks to me an authentication issue with the radius server.
[2] Another thing that I noticed is that when I enter the radius-server information, I get this error
AP(config)#radius-server host auth-port 1812 acct-port 1813 key 7 fHKrJ6U26DQuw5yb
%Invalid encrypted key: fHKrJ6U26DQuw5yb
Why am I getting this error ? When I enter the 'shared secret' without the key word 7, then it works. Not too sure if this is the problem with my laptop not getting an IP.
Pls enlighten,
Thank you,
- InternetB -
Overall Rating: 5 (1 ratings)
InternetB Fri, 02/20/2009 - 01:34
Should the command to enter the radius-server command be :-
radius-server host auth-port 1812 acct-port 1813 key 0 fHKrJ6U26DQuw5yb ?
Add the number 0 to make it not encrypted ? But what is the reason for this to happen in the first place ?
- InternetB -
Stephen Rodriguez Fri, 02/20/2009 - 10:28
yes, you want to use "key 0 "
when you use the "7", it is assuming you are applying a key that has already gone through the service=password encryption algorithm.
