ASA VPN client locking
Feb 20th, 2009
I am running an ASA with multiple VPN Client groups, all authenticating against the same AAA server. Is there a way of preventing a user connecting on an individual group if the know the PSK.
What I want to be able to do is publish the PCF files internally, but prevent unauthorised access.. i.e. only users in the Finance AAA group can connect to the Finance VPN, but everyone can connect to the Users VPN group.
I want to keep as much configuration on the ASA as possibly, with just authentication on the AAA, as we may change AAA server in the future.
Overall Rating: 4.3 (3 ratings)
Syed Iftekhar Ahmed Fri, 02/20/2009 - 13:02
First you will have to create multiple group-policies on ASA for different type of users.
Then you will have to configure the 25 radius attributes on ACS with the name of
the group-policy you want to have the user linked to.
After Successful authentication, ACS will include the attrib 25 (group-policy) in response. ASA will assign user the thr group policy it received from ACS.
After Authentication ACS will response back with Group-policy name and ASA will use that group-policy for the user.
Syed Iftekhar Ahmed
eelsenbach Mon, 02/23/2009 - 08:52
I've recently just done this.
Syed has the acs part down.
Heres a sample config part for ASA.
group-policy VPNC_TEST_GP attributes
group-lock value TEST_VPN_GROUP
default-domain value MYDOMAIN.COM
tunnel-group TEST_VPN_GROUP type remote-access
tunnel-group TEST_VPN_GROUP general-attributes
address-pool TEST_POOL
authentication-server-group RAD_VPN_GRP LOCAL
accounting-server-group RAD_VPN_GRP
default-group-policy VPNC_TEST_GP
tunnel-group TEST_VPN_GROUP ipsec-attributes
pre-shared-key *
On ACS, Group setting Radius IETF ATTR 25
OU=VPNC_TEST_GP;
