IPS will not log into the sensor
Feb 20th, 2009
Before I restart the ASA, here is my problem....
I can log into the ASA, ASDM with no problem, however when i try to connect to the IPS through ASDM is says "error connecting to sensor. Error Loading sensor"....
Any ideas? I want to make rebooting the last option...
rhermes Fri, 02/20/2009 - 09:35
  • Gold, 750 points or more
Can you ssh to the management IP address of the sensor? Rebooting the sensor is not your last option, re-imaging the sensor is.
