Nortel Alteon to Cisco ACE Modules
jteixido
Has anyone coverted their load balancing in thier network from the Nortel Alteon to Cisco ACE Modules?
John...
Mihai Manole
currently i am in the situation that you were in 2009: i have to migrate from nortel 2424-ssl to cisco ACE. untill now i have found no tool for this.
Anyone has any update | info.
Any hint will be highly appreciated
ajayku2
I am not aware of any tool so far. But there are lot of documentation which can help you to configure ACE and troubleshoot as well.
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Configuration_Examples
For Migration of Nortel 2424 SSL ( SSL services ) you can use the following link :
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Configuration_Examples_--_SSL_Configuration_Examples
For troubleshooting you can use the following :
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Troubleshooting_Guide
Hope that helps.
regards,
Ajay Kumar
Thanks a lot Ajay!
honestly i was hoping to find a cisco config convertor but no luck in this. My problem is that i have never worked with Nortel and ACE [at least at this level] so i will have to learn them both now.
I will use the links you have provided and hopefully i will find the light at the of the tunnel
Thank you again.
Mihai
Hi Mihal,
I know it is painful. But you can use the following link and some hint to grasp it faster.
All the best.
regards,
Ajay Kumar
http://docs.oracle.com/cd/B14099_19/core.1012/b13998/sampleconfig.htm
/c/slb/real 1
ena
rip 192.168.0.104   <<< This is like rserver in ACE
inter 15
retry 6
/c/slb/real 2
ena
rip 192.168.0.105   <<< This is like rserver in ACE
inter 15
retry 6
/c/slb/group 1    <<< This is like serverfarm in ACE >>
metric roundrobin
add 1
add 2
vip 192.168.200.10    <<<< This is like virtual ip in ACE >>>>
dname "linux.pdx.com"
/c/slb/virt 1/service http
group 1
