6500 boot issue
Feb 20th, 2009
  • Purple, 4500 points or more
Have a sup 720 that boots into rommon . I can see that the supervisor config register is not right . How do I change it on the supervisor once its booted up ? I remote command into the supervisor but don't see an option to change the config register in there . Have looked around on CCO and I probably missed it . Is there a easy way to do this once the box is booted up ?
Overall Rating: 3 (1 ratings)
glen.grant Fri, 02/20/2009 - 09:07
Right Edison the problem is at the switch processor level not the route processor which is correct at 2102 . I changed it when it stopped at the rommon prompt and its ok now . I was just wondering if there is a way when its booted all the way up to change the switch processor config register , couldn't find any command to do it when I remoted into the switch processor.
Edison Ortiz Fri, 02/20/2009 - 09:14
  • Hall of Fame,
    Founding Member
I'm afraid there isn't.
I encountered a similar problem at a customer site.
I tried using the remote commands and they didn't work.
Glad my suggestion solved your problem.
__
Edison.
