Help configuring CUBE
Feb 20th, 2009
I apologize if at some point I don't use the correct terminology. I have just received a CUBE but I am not sure where to start. Here is how it will be connected:
outsideCube ----metroE link ---- myCube --- myFirewall ---myinside network
I would like to know how to configure the following:
1. Cube itself. What do I need to configure so I can neighbor it with the other one?
2. I need to enable the gateway feature.
3. I have CCM 4.1, should I register it with the CUBE or Gatekeeper? How?
4. Dial-peer and Dial-plan
I really need some help in order for me to get this done as soon as possible.Thank you very much.
