ISP Load sharing with failover functionality on ASA
Feb 20th, 2009
I have seen configuration Sushil (suschoud) had posted in the link below.
Firewalling: Two ISP connections into an ASA 5510?
<A HREF="javascript:newWin('')"></A>
The configuration looks great. Anyway, I would like to confirm if it is possible to add failover functionality to that configuration. For example, in normal state, default gateway goes through ISP1 and web routes via ISP2 but if ISP1 failed, all traffic (including web) go through ISP2 instead. On the other hand, if ISP2 failed, all traffic route via ISP1 instead. Would it be possible? Is it done by object tracking?
Please advice.
