MIB for Supervisor Engine 6-E
Feb 20th, 2009
Does anyone know what MIB I can use for a Catalyst 4500 Supervisor Engine 6-E? I've been looking in the MIB locator at cisco.com and can't seem to locate one that supports the Supervisor 6-E. If anyone knows please forward this on to me. Thanks.
g.lafreniere Fri, 02/20/2009 - 14:54
I was unable to get any info from [email protected], it just came back with a message that said MIIM failed to find any MIBs in this image. The image we are running is cat4500e-ipbasek9-mz.122-46.SG.bin. I am unable to find any MIB's that will support Catalyst 4507R-E running a Supervisor Engine 6-E. I even looked into the most recent IOS version, but it seems the Supv engine 6-E is just not supported. Any suggestions?
Joe Clarke Fri, 02/20/2009 - 21:25
I just added support to MIBs In Images for this platform. Resend the email.
g.lafreniere Wed, 02/25/2009 - 07:42
I've got all the MIB's downloaded that were listed in the e-mail from ftp://ftp.cisco.com/pub/mibs/v2/ as you said to do. I then followed the link to attempt to load the MIB's into Cisco Network Assistant at http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800b4cee.shtml, as you said to do. The only problem I'm having right now is this link shows us how to load the MIB's into a third party NMS and not Cisco Network Assistant. Is there a procedure somewhere that can direct us on how to get the MIB's loaded into CNA?
Joe Clarke Wed, 02/25/2009 - 10:09
I do not think you can load MIBs into Cisco Network Assistant. It should have all of the support it requires already. What problems are you seeing in CNA?
g.lafreniere Wed, 02/25/2009 - 11:13
When we have CNA open and are looking at the topology view of our switches, you should be able to right click on a device and select "Device Manager" and it will take you to a Dashboard GUI Interface. It is a very useful function to have. We are unable to do this with our Catalyst 4507R-E Supervisor engine-6 switch. When you right click on the 4507R-E and select "Device Manager", it then takes you to an HTML page. When you get to this page and select "manage the switch through GUI-interface application" it takes you to an error page at Cisco.com that says "the page you have requested is not available". We have been trying to get some kind of fix in place that will allow us to use the GUI based application with our 4507R-E Supv-6 switch but have been unsuccessful up to this point.
Joe Clarke Wed, 02/25/2009 - 11:30
It looks like you already have a TAC service request open for this. You should continue working with them to resolve this. I do not use CNA, and I am not certain what the problem could be. However, the page CNA redirects you to may be an important clue. The URL may give some idea of what information the page should have displayed.
g.lafreniere Thu, 02/26/2009 - 08:28
I understand. Unfortunately the other person who was working the TAC service request hasn't contacted me in days after several attempts to contact him. Also, he was the one instructed me to download the MIB's and try to put them in CNA, which as it turns out was incorrect. Is it possible for me to get the current case closed and have a whole new case reopened and worked by a different engineer? It seems as I have come to a point where I have nowhere to go from here.
Joe Clarke Thu, 02/26/2009 - 09:36
You can always contact the Global Contact Center agent, and have your service request requeued, or have the engineer paged.
