Diagnostic Monitoring is not implemented
Feb 20th, 2009
Hi All,
We are trying to find the reason and solution for the below problem. We are tring to perform the below command and get the below message.
router#show interfaces gigabitEthernet 5/1 transceiver
Diagnostic Monitoring is not implemented.
The module on which the above gig interface is WS-X6408A-GBIC and the IOS version running on this router is s72033-advipservicesk9_wan-mz.122-18.SXF11.bin. The sup on this router is SUP-720-3BXL.
Any help to understand why it is giving that message and the solution to overcome the same would be really appreciated.
Anantha Subramanian Natarajan
WS-X6408A-GBIC --Module 5
SUP-720-3BXL
Overall Rating: 4.5 (2 ratings)
anasubra_2 Fri, 02/20/2009 - 16:37
Hi baileyshbr,
Thank you very much and I have to check the GBIC's .
reamea chey Fri, 04/27/2012 - 03:15
s-01-pnh-asr#sh interfaces gigabitEthernet 0/25 transceiver detail
Can't see anything.
