UC520 turned into a brick during CCA upgrade
Answered Question
Feb 20th, 2009
It seems that when going through an upgrade, if CCA hangs, its already deleted the IOS and now when I reboot the UC520, its a brick. How do I get the IOS back on the flash?
Correct Answer by paolo bevilacqua about 8 years 4 months ago
When you type it without parameter, it shows the environment variables that you have to set, like IP_ADDRESS=10.10.10.10
When all variable are set correctly, it will proceed to copy file to flash, or there is an option to only load image and boot.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Fri, 02/20/2009 - 10:31
  • Hall of Fame,
    Founding Member
Connect serial console. Boot and report output here.
patrick.hurley Fri, 02/20/2009 - 10:52
Its in rommon mode. there is a command tftpdnld that I can use but haven't been able to figure out the syntax.
Correct Answer
paolo bevilacqua Fri, 02/20/2009 - 10:56
  • Hall of Fame,
    Founding Member
patrick.hurley Fri, 02/20/2009 - 12:07
Can you type an example that actually works? I cannot find the right string.
paolo bevilacqua Fri, 02/20/2009 - 13:07
  • Hall of Fame,
    Founding Member
You're welcome. Please remember to rate useful posts with the scrollbox below.
