02-20-2009 10:26 AM - edited 02-21-2020 03:18 AM
We use Cisco VPN 3000 for remote access using VPN client. Do I really need to use Cert from Verisign for my public interface? We don't use WebVPN but even though we use do we really need that cert? Please advice.
T
02-20-2009 10:34 AM
Well known trusted vendors like Verisign are "needed" if you use webvpn or ssl connections to your CVPN only if you need to have your VPNC certified as a trusted device, in your case since your concentrator is not using webvpn nor ssl and you are only using VPN Client, you don't really need a certificate at all. Unless your vpn clients start authenticating using PKI (in which case you would not need a Verisign cert either)
02-20-2009 10:43 AM
Thanks for your quick response and advice. That's what I thought but not 100% sure.
