No Vlan on ASA
Feb 20th, 2009
I have a new ASA5510,,that cannot and will not allow interface Vlan additions or configuration...when i type Conf t and then interface ? no vlan keyword shows up..I have updated IOS etc...the only thing I can think of is that they sent me a Failover ASA...does that sound familiar to anyone
eddie.mitchell@... Fri, 02/20/2009 - 12:38
  • Silver, 250 points or more
What does the output of 'show ver' display? It should contain an entry for maximum VLAN's.
robertson.michael Fri, 02/20/2009 - 13:55
Hi Dane,
You can configure VLAN interfaces on ASA5510 and greater using subinterfaces. Here is an example:
ASA(config)# interface GigabitEthernet0/1
ASA(config-if)# nameif
ASA(config-if)# security-level
ASA(config-if)# no ip address
ASA(config)# interface GigabitEthernet0/1.2
ASA(config-if)# vlan 2
ASA(config-if)# ip address
Hope that helps.
-Mike
