Policy based routing
Feb 20th, 2009
in our Lan network we are using Surfcontrol web filter to block certain iinternet access which is connected to (default gateway for internet) the packet going through the gateway was catured and blocked by the server
Since all service traffic is inspected by surf control i thought of differentiating the traffic by service like port 80 traffic should go via and all other service traffic should go via other gateway
i tried policy based routing in catalyst 6500 for that like below
#Access-list 101 permit ip any eq 80 any eq 80
# route-map access permit 10
#match address 101
#set ip nexthop
all other traffic will go to the default route
#ip route
is that right
please suggest me
Tshi M Fri, 02/20/2009 - 12:00
Shouldn't your ACL allow TCP rather than IP? I mean:
access-list 101 permit tcp any any eq 80
JamesLuther Fri, 02/20/2009 - 12:03
Looks good apart from your access-list should be
You will also need to apply the PBR to the ingress interface of where the traffic is coming from, like below
interface Vlan 99
ip policy route-map MY_MAP
Or you can apply it globally like below
ip local policy route-map MY_MAP
vinoth.kumar Sat, 02/21/2009 - 04:41
sorry i have done the same also but still its not working
my doubt is whether we need to configure dummy route map pointing to null 0
why null0 is required
JamesLuther Sat, 02/21/2009 - 05:00
Where have you applied the route-map? Have you applied it to an interface or the global routing table (with "ip local" shown above).
Remember route-maps only apply to traffic coming IN to a layer 3 interface.
Make sure the traffic that you're trying to match is coming in the interface that you've applied the route-map (or apply to global routing table).
vinoth.kumar Sat, 02/21/2009 - 05:37
here is my config in 6500
interface Vlan195
ip address
ip policy route-map accesstoport80
interface Vlan211
ip address
route-map accesstoport80 permit 10
match ip address 111
set ip next-hop
ip route
suggest me were i went wrong
Richard Burts Sat, 02/21/2009 - 08:28
The obvious issue is the mismatch where you show us access list 101 but the route map is matching access list 111. Does access list 111 exist?
