I forgot router's password
husseinmuneer
I have a router in a remote site and there is no body there to make switch off and switch on or to make password recovery so I can make telnet to this router and I have the VTY password but after I entered to the router like this:
telnet 192.168.1.136 ....
Password: cisco
Router12>en
password: ( I forgot it )
My question can I make something to enter to the router instead of I travel to the place where the router installed in to make password recovery?
Note:
when I made the configuration I entered the following command:
enable secret password .....
Thank you for your help.
Richard Burts
muneeer
The optimum solution is to discover what you had configured as the enable secret:
- try the password with CAP lock on, and try with it off.
- try the password with a trailing space.
- try the password with various possible keystroke errors (perhaps a t instead of a g, etc).
The next best solution is to have out of band access to the router (perhaps a modem connected to the console port).
The next best solution is to ship a replacement router to the site and have someone replace the existing router (for which you do not know the password) with a router for which you do know the password.
The ultimate fallback solution is to plan a trip to the remote location and to do the password recovery procedure.
Rick
Rick
