passive - distribute-list help!!!!!
Answered Question
Feb 20th, 2009
Hello All,
I have a situation and I need help. I don't want the WAN router to learn a subnet that is coming out of two LAN routers (10.10.10.0/24) and let other ones through (see diagram) I was thinking about passive-interface with a distribute-list, but because of the type of switches (Cat6k-MSFC2) I don't know how to apply it. Any suggestion would be greatly appreciated.
Thank you very much for your assistance.
Cheers!!!
Correct Answer by Edison Ortiz about 8 years 2 months ago
Mauricio,
Per your diagram, you will apply the distribute-list in under the EIGRP process in the WAN router, pointing to the interface that is connected to the L2 switch.
The list will reference an ACL that blocks 10.10.10.0/24 and then permit any
Please refer to the documentation on the syntax:
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi1.html#wp1018093
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Richard Burts Fri, 02/20/2009 - 12:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mauricio
I believe that there is some confusion in your question. You say that you are thinking about using passive-interface with a distribute-list. But passive-interface does not work with distribute-list. If you have passive-interface then the router learns no routing updates on that interface. With a distribute-list the router can learn certain routes through the interface but does not learn certain other routes. From your description I believe that you need distribute-list and not passive-interface.
Rick
mguzman4158 Fri, 02/20/2009 - 13:03
Thanks Rick, now where and how would apply the distribute-list?
Cheers!
Correct Answer
Edison Ortiz Fri, 02/20/2009 - 13:20
  • Hall of Fame,
    Founding Member
Mauricio,
HTH,
__
Edison.
