Converting to MPLS - BGP question
Answered Question
Feb 20th, 2009
We're converting our existing connections to an MPLS based solution. We run bgp with our provider.
We're going to be installing wics in the existing routers that will be connecting into the new run. I'm going to set these wics to support the new connection, but we'll be peering with the same provider. Is it okay if I have the following:
router bgp 500
neighbor 5.5.5.1 remote-as 525 (old connection)
neighbor 10.10.1.1 remote-as 525 (new connection)
The router will let me do it in a lab, but I'm not peering with anyone in the lab. I did a "sh ip bgp summary" and I see both neighbors in the table, which tells me that it's a valid way of doing it. I have to be able to peer the new connection with bgp before moving over to the new connection.
John
Correct Answer by Mohamad Qayoom about 7 years 11 months ago
Yes, you can peer with the same provider as you explained. You can peer with the new connection before removing the old one.
We are currently running BGP and have two neighbors in the same AS.
Mohamad
Overall Rating: 5 (1 ratings)
Correct Answer
Mohamad Qayoom Fri, 02/20/2009 - 13:03
Mohamad
