How to use command set authorization in ACS server
subharojdahal
Folks,
Could anybody please tell me how to assign limited command set to specific user ( group ).
What I did in ACS Server
1.Create a shell command authorization set.
2. configure user to use just defined authorization set under group->shell command authorization set.
3. I dont know which enable options to use but i click no enable options.
I appreciate if anybody could help me out to set up limited commands authorization for my specific admin.
thnx
subharose
Yudong Wu
Level 7
Level 7
Under TACACS+ setting:
select "shell(EXEC)"
set privilege level to "15".
Then you need configure your router/switch to enable aaa authorization.
