An Uncalled-for DR Election in OSPF
Feb 20th, 2009
Four routers are connected via token-ring in Area 0. RID is DR, is BDR. DRothers are and
I powered down. Switched it right the hell off. Felt no guilt; would do it again.
I was logged on, console-like, to Router G ( with OSPF Adjacency debugging activated, and here's part of what I saw:
01:08:28: OSPF: address on TokenRing0 is dead
01:08:28: OSPF: address on TokenRing0 is dead, state DOWN
01:08:28: %OSPF-5-ADJCHG: Process 100, Nbr on TokenRing0 from FULL to
DOWN, Neighbor Down: Dead timer expired
01:08:28: OSPF: Neighbor change Event on interface TokenRing0
01:08:28: OSPF: DR/BDR election on TokenRing0
01:08:28: OSPF: Elect BDR
01:08:28: OSPF: Elect DR
01:08:28: DR: (Id) BDR: (Id)
The router that went down was neither DR nor BDR. Why was there a DR election reported? Does this always happen when there's a neighbor change event on a multiaccess interface? That doesn't jibe with my training, which says that an election won't take place unless the existing DR goes down.
marikakis Sat, 02/21/2009 - 07:59
You are right and this is not normal behavior. DR election in OSPF is not even preemptive. The routers that go into the election process in your case are running buggy software. I have come across this issue before.
Mohamed Sobair Sun, 02/22/2009 - 01:02
According to the RFC, when topology changes (Router failure), a new election of a DR has to occur. This applicable in the Multi access Networks of course where there is DR & BDR election.
