vrrp and hsrp
Answered Question
Feb 20th, 2009
I would like to enable redundancy in our netwrok. It seems that there are two possible approaches. They are HSRP and VRRP. they are much similar. what is the major different between them (HSRP and VRRP)?
rdgs
Correct Answer by Giuseppe Larosa about 8 years 1 month ago
Hello Anita,
VRRP is standards based and can be used in a multivendor environment.
HSRP is Cisco proprietary.
see
for VRRP
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_vrrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1054602
for HSRP
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_hsrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html
You may be interested in GLBP that allows for real load balancing.
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_glbp_ps6350_TSD_Products_Configuration_Guide_Chapter.html
To be noticed that in the list of features of VRRP the load balancing capability is listed but I don't understand if it says that using multiple VRRP virtual routers is the way to do it.
My understanding is that HSRP and VRRP are now comparable and that GLBP provides effective load balacing.
Also in 12.4 is present object tracking that was missing for VRRP when it was introduced in Cisco IOS.
HSRP can emulate load sharing using multiple groups in the same subnet. And VRRP can do the same.
There are scenarios where HSRP or VRRP are a better choice when you want to implement redundancy without load balancing.
Hope to help
Giuseppe
Correct Answer by johnlloyd_13 about 8 years 1 month ago
hsrp is cisco proprietary while vrrp is industry standard. their major difference would be their timers. hsrp uses a default hello timer of 3 seconds and a hold timer of 10 seconds. on the other hand, vrrp has faster timers with a hello of 1 second and a hold timer of 3 seconds. although you could tweak hsrp timers to make it feel like you're running vrrp. if you're using cisco devices, i would recommend glbp, which adds load balancing.
Overall Rating: 5 (2 ratings)
Correct Answer
johnlloyd_13 Fri, 02/20/2009 - 22:21
  • Blue, 1500 points or more
Correct Answer
Giuseppe Larosa Fri, 02/20/2009 - 22:34
  • Hall of Fame,
    Founding Member
Hello Anita,
see
for VRRP
for HSRP
Hope to help
Giuseppe
