ACE multicast MAC
glenn.ong
Hi experts,
Have a question here. Our ACE 4710 is setup to forward traffic to a CheckPoint Cluster VIP as default gateway. As the checkpoint active/active cluster is using multicast mode..it basically uses an unicast ip with a multicast mac.
As with most L3 devices, ACE doesn't like this and will not ping to the cluster ip. Normally we can add a static arp entry but when i try adding the cluster virtual mac in the ACE it always gives an "Error: Invalid MAC address".
I'm pretty sure it's not a typo. any thoughts on this or other potential workaround?
thanks heaps.
You got it right.
ACE doesn't like Multicast MAC addresses.
In order to overcome this limitation ,
You can create an SVI on the switch for the same VLAN (Vlan connecting FW & ACE) and define the SVI's IP address as the default gateway on ACE.
Syed Iftekhar Ahmed
juanrin75
You can configure a VRF instance between the ACE and the FW. This adds up one hop in your routing scheme but configuring a new SVI could lead to open new holes in your network infrastructure, especially when you have all your devices attached in a vlan that hadn't a SVI before and the switch has other L3 interfaces in the inside network. Then you add a static arp entry in your virtual routing forwarding instance arp table and configure routes to bypass the traffic in both directions.
