MST Vs PVST
Answered Question
hello
what is the difference between HSRP and VRRP?and between MST and PVST?
Correct Answer by Giuseppe Larosa about 8 years 2 months ago
Hello Ali,
VRRP is standard based and can work in a multivendor context
HSRP is Cisco proprietary.
The two protocols provide default gateway redundancy
see
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd23312
b) MST and PVST
Per vlan STP executes an STP instance for each L2 vlan that has a port (access or trunk) associated to it.
MST 802.1s standard allows to use up to 16 STP instances to represent 4094 vlans.
so in MST multiple vlans are associated to a single STP instance (each instance is rapid SPT 802.1w)
this provides scalability
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Sat, 02/21/2009 - 03:32
  • Hall of Fame,
    Founding Member
Hello Ali,
see
b) MST and PVST
Hope to help
Giuseppe
