improve my network
Answered Question
Feb 21st, 2009
if i want to improve my network what is the most important specification in the switch and router shewed i look to it ?
i will change the router and switch in LAN and wan network
Correct Answer by Haris P about 8 years 2 months ago
This depened on your requirement and the budget .
Please see the attached document which will help you to decide regarding switch/router
http://www.cisco.com/en/US/products/hw/switches/index.html
Haris
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Sat, 02/21/2009 - 06:34
". . . what is the most important specification in the switch and router shewed i look to it ? "
That's very much "in the eyes of the beholder". I.e., depends on your network requirements. That said, minimally, you often want to insure that switches or routers can handle the intended traffic load, yet not purchase capacity that will never be used. Next, insure the equipment offers the features your network needs to function as desired. For instance, if your network will support VoIP, you'll probably want some kind of QoS features to insure VoIP packets can be provided the priority treatment they need.
