MPLS/BGP - Route Restriction
Feb 21st, 2009
I'm new to the whole MPLS Setup. I'm trying to connect remote sides using BGP on the providers side and OSPF on our side.
I receive lots of routes of Service Provider, is there a way to block these routes at MPLS Router without ACL
Giuseppe Larosa Sat, 02/21/2009 - 12:04
Hello Ronald,
if the service is a Layer3 VPN and you think you are receiving more routes then necessary and you see routes that don't belong to your remote sites contact the MPLS service provider tech support they can have made an error and they may have joined two VPNs of two different customers.
if all is configured correctly you should see only your routes
Hope to help
Giuseppe
