02-21-2009 12:10 PM - edited 03-04-2019 03:40 AM
Hello Experts i am having a problem and i want to sort it out i have a CISCO 1720 series router and i want to connect that router to internet. can any body tell me by using which WAN technology or devices i can connect my this router to internet like T1 and E1 lines or any other WAN technology please help me out i am facing this problem very badly also mention the devices which are required other then CISCO router to connect to internet. i have also attached a file which represent the scenario which i have briefly explained to all of you. waiting for your reply
Best Regards
Ahmad Ellahi
02-21-2009 04:54 PM
You can only use WIC-1ADSL or WIC-1SHDSL (http://www.cisco.com/en/US/docs/routers/access/1700/software/feature/guide/GSHDSLup.html).
Take note that you need to verify if your IOS meets the standard.
Hope this helps.
02-22-2009 10:07 AM
Well friend it is a good solution which you have proposed for me but i want either T1 line or E1 line connecting to my router in that case what will be the solution.
Best Regards
Ahmad Ellahi
02-22-2009 11:47 AM
Ahmad,
Please refer to the following document:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_relevant_interfaces_and_modules.html
for a list of available WAN modules for your router.
If you want an internal CSU/DSU for your T1 line, I recommend getting the WIC-1DSU-T1-V2 module.
HTH,
__
Edison.
02-23-2009 09:32 AM
Thanks a lot.
