02-21-2009 01:05 PM - edited 03-15-2019 04:22 PM
I get a busy when I pick up the phone and dial 9 but I can call into the number.
Solved! Go to Solution.
02-21-2009 02:29 PM
Mistakes can happen. Please check it is working for you and confirm.
You can rate any post you have not rated before, anytime.
02-21-2009 01:07 PM
Config problem, check your dial-peer.
02-21-2009 01:55 PM
Fixed it.
02-21-2009 02:02 PM
You don't have one, just the crap that the wizard puts in there.
Put lines actually connected in trunk-group
voice-port 0/1/2
trunk-group fxo
dial-peer voice 9 pots
destination-pattern 9T
trunkgroup fxo
The eliminate DPs 50 - 53, these are really useless.
Note, you cannot professionally configure UC520 without getting familiar with DPs, etc.
02-21-2009 02:17 PM
Edited...
02-21-2009 02:20 PM
My mistake. Meant to give you a 5. Is there any way to fix it?
Yes I was using the wizard, and I saw what I did wrong and did fix it. Thanks for your help.
02-21-2009 02:29 PM
02-21-2009 02:32 PM
Yes it works. I am testing the interface for a Cisco instructor. I was trying to be funny by pasting the whole thing in the post and saying "which one."
I found where it didn't have the right information and fixed it.
You are very helpful and thanks for being on Netpro!!
