Cisco 857w - Restore to Factory Default?
Feb 21st, 2009
Does anyone know the procedure to restore the 857w Router to factory default? I've recently moved and have since forgotten the password to the device. The router is now useless and I'd like to simply start over.
Any help greatly appreciated!!
Giuseppe Larosa Sat, 02/21/2009 - 23:07
  • Hall of Fame,
    Founding Member
Hello Nate,
there is a password recovery procedure
see
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/trouble.html#wp1038210
you need to connect with a console cable using a terminal emulation SW like hyper terminal
to type the break at router startup use
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
Hope to help
Giuseppe
natestreet Sun, 02/22/2009 - 05:03
Thank you Giuseppe!
I'm afraid I am an absolute amateur when it comes to Cisco devices however. I stumbled upon those instructions earlier, however, I am not familiar with how to actually connect THROUGH the console cable.
I opened up telnet in Windows and typed Console, however, nothng happened. What port are connecting through? LPT1?
Very confused. Do you know exactly which program I should use and how exactly I will connect. I do have the blue cable that came with the device, however, I am not sure how to specify that cable to communicate through!
Thanks again!
Giuseppe Larosa Sun, 02/22/2009 - 06:03
  • Hall of Fame,
    Founding Member
Hello Nate,
the blue cable should have one side that is a DB9 you need to connect it a serial port like COM1.
the other side that is like a LAN cable (RJ-45) is to be connected to the router port labeled console
if you have a modern laptop the DB9 serial port can be missing. In this case you should buy an RS-232 to USB adapter
Hope to help
Giuseppe
natestreet Sun, 02/22/2009 - 07:50
Hi Giuseppe:
Thank you, once the cable is connected how do I communicate to the router through a hyper terminal?
You would never know I'm a Network Admin! I work with Windows Server.
Nate
natestreet Tue, 02/24/2009 - 22:04
Well, I now discovered a new application in Windows XP...they really dug Hyperterminal down in windows pretty well...
Ok, so I can now connect to the router through the COM1 port (blue cable).
After it goes through the boot sequence it prompts me for the username and password, which I do NOT know! What I want to do at this point is reset the router to factory settings. The instructions are asking me to enable the "Break" sequence, however, I do not know what I need to do in order to perform this sequence.
Do you know what they are referring?
Giuseppe Larosa Wed, 02/25/2009 - 12:04
  • Hall of Fame,
    Founding Member
Hello Nate,
in hyperterminal you need to use CTRL+Break to send break during the bootstrap phase
reread the links I've provided in my first post they provide the password recovery procedure and a link to break sequences
Hope to help
Giuseppe
natestreet Mon, 03/02/2009 - 07:40
And the search continues!
Ok, The CTRL-BREAK did the trick and I was able to run the Reset the Password Utility.
Now the question seems to stem around whether or not this ACTUALLY reset the password and configured the router to factory settings.
Upon reconfiguration I did see the username I used originally to configure the router. This was after I thought I had "reset" the configuration.
Right now, I'm just hoping to find out what the default IP/Subnet of the router is? It looks like it should be 10.10.10.1/16 however, I am unable to ping the router at that address! Ideas!?
Giuseppe Larosa Mon, 03/02/2009 - 12:54
  • Hall of Fame,
    Founding Member
Hello Nate,
the password recovery procedure has the objective to allow privileged access to the router.
the config-register 0x2142 tells the router to ignore the configuration file including the passwords.
But it doesn't erase them and doesn't erase the config file.
Then once you get the router# prompt you can override username/pwd pairs and the enable secret.
if you perform
copy startup-config running-config you load actually the configuration file (and the router executes the commands).
you then can list the configuration this can be enough for the username/pwd pairs (if service passwords encryption is not enabled the only encrypted password is the enable secret)
just override what you cannot read.
at the end remember to do the following:
restore the original config-register
conf t
config-register 0x2102
end
copy running-config startup-config
otherwise the config will be ignored also at next router reload !
Hope to help
Giuseppe
