PortForwarding in PIX515
Feb 22nd, 2009
Hi All,
My ip is 1.1.1.1 this ip is forwarded to my leased line link from SP. Now i want to confgiure this ip with port forwarding in order to point to my server(192.168.1.2) in DMZ. My topology is
Internet--InternetSwitch--Pix515--DMZ
Any Clues for configuration??/
Jon Marshall Mon, 02/23/2009 - 03:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
As an example we'll port forward http (tcp port 80).
1) if 1.1.1.1 is the outside interface address of your pix
static (dmz,outside) tcp interface 80 192.168.1.2 80 netmask 255.255.255.255
2) if 1.1.1.1 is just a spare address you have
static (dmz,outside) tcp 1.1.1.1 80 192.168.1.2 80 netmask 255.255.255.255
note you need to use the interface name in your configuration so i have assumed your DMZ interface is called dmz ie. static (dmz,outside) .... If it is called something else use that.
You then need to update your acl or create one if you haven't already got one
access-list outside_in permit tcp any host 1.1.1.1 eq 80
access-group outside_in in interface outside
Jon
Jon Marshall Mon, 02/23/2009 - 03:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
outside_in is just a name i usually call an acl applied to the outside interface. Doesn't matter what name you use as long as you apply it to the outside interface ie.
access-group in inteface outside
Jon
