PIX515 port forward
sohaildxbfze
Hi All,
My ip is 1.1.1.1 this ip is forwarded to my leased line link from SP. Now i want to confgiure this ip with port forwarding in order to point to my server(192.168.1.2) in DMZ. My topology is
Internet--InternetSwitch--Pix515--DMZ
Any Clues for configuration??/
husycisco
Level 7
Level 7
Hello Sohail,
Here is an example for tcp 80 port forwarding. Considering that you properly configured outside interface IP as 1.1.1.1
static (dmz,outside) tcp interface 80 192.168.1.2 80
access-list outside_access_in permit tcp any interface outside eq 80
access-group outside_access_in in interface outside
5 Replies 5
husycisco
Level 7
Level 7
Hello Sohail,
sohaildxbfze
I want to elaborate more.
my public ip is 1.1.1.1/24, out of this /24 i want to use lets say 1.1.1.2 as forwarding to my dmz 192.168.1.2 server with any port, so 1.1.1.2 will not be used on any host just a forwarder. Then 192.168.1.2 shld also be natted as 1.1.1.2 to internet, also 192.168.1.2 will access my inside server farm 192.168.3.x network
Appreciate ur ans..
"my public ip is 1.1.1.1/24, out of this /24 i want to use lets say 1.1.1.2 as forwarding to my dmz 192.168.1.2 server with any port, so 1.1.1.2 will not be used on any host just a forwarder. Then 192.168.1.2 shld also be natted as 1.1.1.2 to internet"
Below config will achieve what you want above
static (dmz,outside) 1.1.1.2 192.168.1.2 netmask 255.255.255.255
But I didnt understand this part
"also 192.168.1.2 will access my inside server farm 192.168.3.x network "
ignore that part, wz pasted by mistake,
i craeted static as u told.
then created
acl_outside_in permit ip any host 1.1.1.2
when tried to ping 1.1.1.2 didnt able to capture anything.. i can reach only to my wan ip
For ping, you should include
acl_outside_in permit icmp any host 1.1.1.2 echo
