E1 Cable Length Limitation
Feb 22nd, 2009
I need to know the E1 cable length limitations,in meters? Actually i've a customer who needs to extend their E1's from the basement to DataCenter Room and you people know the UTP Cable limitation. So which type of device should i refer to them for this purpose.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Sun, 02/22/2009 - 09:19
  • Hall of Fame,
    Founding Member
UTP gauge 22, typical attenuation, should cover 1000 feet ( > 300 m) without problem.
Make sure you use proper cable and respect the pair twisting, that is NOT like ethernet.
marahman78 Sun, 02/22/2009 - 09:47
The distance is around approx 500 meters. What did u think ? It will work or not ?
Paolo Bevilacqua Sun, 02/22/2009 - 09:53
  • Hall of Fame,
    Founding Member
Should not work. You can use a pair of hdsl modems/extenders.
