Runts and Giants on 3750
Feb 22nd, 2009
My 3750 is showing the following errors (runts,giants,input errors):
FastEthernet 1/0/13
VPN Concentrator
0 runts, 5 giants, 0 throttles
22 input errors, 17 CRC, 0 frame, 0 overrun, 0 ignored
FastEthernet 1/0/2
Trunk to ASA Firewall
561 runts, 0 giants, 0 throttles
562 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
Should I clear the stats down first and check later? If so how?
Also in basic terms are these errors?
JamesLuther Sun, 02/22/2009 - 12:41
  • Silver, 250 points or more
To clear the statistics then type
clear interface fa1/0/13
clear interface fa1/0/2
runts are packets that are too small to be classed as a normal packet. Giants are packets larger than the MTU size of the port. CRC is checksum faiulure ie packet corrupted
The input errors are a total count of all errors.
Detailed explanation can be found
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1904.html
whiteford Sun, 02/22/2009 - 12:44
Should the stats clear straight away? I ran those commands and the same stats remain.
[update]
Looks like clear counter interface fa1/0/13 etc did it.
adamclarkuk_2 Sun, 02/22/2009 - 12:49
Try the clear counters command
clear counters [interface-id]
