URL for N-HOP-View im LMS 3.1?
Feb 22nd, 2009
Hi there,
I'd like to integrate the N-HOP-View in our Mgmt-Portal (running on an apache-server).
Is it possible to launch/display N-HOP-View within an IFRAME of a HTML-Page,
and what URL can I use for that?
Thanks for any hint.
Lothar
Overall Rating: 3 (1 ratings)
Joe Clarke Sun, 02/22/2009 - 16:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Embeddable URLs for portlets are coming in LMS 3.2. due out this summer.
lo.mueller Sun, 02/22/2009 - 22:47
Hi Joe,
thanks for the feedback.
Do you know whether there will be a "paper" documenting the available URLs?
To understand it right, in LMS 3.1 there is no possiblitity to lauch portlets from remote?
Lothar
Joe Clarke Sun, 02/22/2009 - 23:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, the porlets which can be embeddable will be documented. No, this is not possible with LMS 3.1.
lo.mueller Mon, 02/23/2009 - 05:22
Hi there,
searching thru the source-text of PORTAL I discovered following URL for launching N-HOP-View Portlet
"https://:443/campus/qtopo/qtopoUI.jsp?ipaddress=&mode=0&nHops=3&showDFMAlert=on&critical=on&warning=on&information=on&duration=2&units=Min"
This one really works.
Lothar
Joe Clarke Mon, 02/23/2009 - 09:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'm glad this worked for you. However, this is not the portlet per se. In LMS 3.2, certain portlets will be embeddable as iFrames into other applications (e.g. iGoogle). As a rule, this will not work in LMS 3.1.
