Hythim Ali El Hadad Sun, 02/22/2009 - 16:51
  • Silver, 250 points or more
Sure you can block a specified incoming calls.
but you can do it only with h323,cme
you cann't do it with cucm unless you use h323 gateway with it.
You'll do it by rule reject /../ under voice translation-rule then apply to aprofile, then apply this profile to your pots dial-peer
wish this be helpful
Best Regards
James Hawkins Tue, 02/24/2009 - 01:00
  • Gold, 750 points or more
A customer of mine had a problem with cold callers calling one of their staff on a direct number and trying to sell them kitchen equipment. This happened 4+ times a day so I was asked to try to block the caller.
As the customer used MGCP gateways the best way that I found to do this was to implement a translation pattern matching the incoming CLI and translating the call destination to the Unity pilot point.
Unity was configured to play a message telling the caller that cold calls were not welcome.
paolo bevilacqua Tue, 02/24/2009 - 01:48
  • Hall of Fame,
    Founding Member
How exactly you route by CLI in CM ? In the past it has been said that it's not possible.
Afragoso2009 Tue, 02/24/2009 - 05:11
Hi Jamesha.Its a good solution
Bu in my case I want to block all incaming call and allow just 5 or 6 that Ia want to call me
