02-22-2009 06:04 PM - edited 03-06-2019 04:10 AM
Hi every body!
i am just wondering which csu/dsu(brand) is most common in asia and usa?
Thanks a lot!
Solved! Go to Solution.
02-22-2009 06:53 PM
Very hard to tell.
If you purchase a Cisco router, you will most likely purchase an internal CSU/DSU.
However, if you were to purchase a non-Cisco router, you would purchase that vendor's internal offering or purchase a 3rd party external CSU/DSU.
Internal CSU/DSUs are ideal as you can manage/configure them directly from the router.
HTH,
__
Edison.
02-23-2009 06:12 AM
It could be an stand alone unit but if you buy a Cisco router, you often end up with the internal option and it looks like this:
http://www.cisco.com/en/US/prod/collateral/routers/ps221/product_data_sheet09186a00801a9184.html
HTH,
__
Edison.
02-23-2009 06:12 AM
Sarah
Yes that is what it means. The internal CSU/DSU has the functionality built into the serial card. The CSU/DSU functions take place within the chassis and there is no external unit.
Rick
02-23-2009 06:56 AM
All current Cisco routers have a slot allocated for internal CSU/DSUs.
The last router NOT to have a slot allocated for internal CSU/DSU was the 2500 Series router which was a non-modular router.
02-22-2009 06:53 PM
Very hard to tell.
HTH,
__
Edison.
02-22-2009 11:00 PM
Thanks a lot Edison!
What do we mean internally? Does it mean csu/dsu is not stand alone unit,rather implemented inside the chasis.
02-23-2009 06:12 AM
HTH,
__
Edison.
02-23-2009 06:48 AM
Thanks Edison!
Do the routers such as 2600 xm come with bay which can be removed to install this csu/dsu card or this card comes pre-installed in routers?
thanks a lot!
02-23-2009 06:56 AM
02-23-2009 06:12 AM
Sarah
Rick
