PIX 525 write standby issue
Feb 22nd, 2009
When I execute write standby command from primary PIX it is not copying one particular command line to the standby secondary PIX the command is "nat (inside) 0 access-list inside_nat0_acl"
even after rebooting secondary PIX I am having this issue. Other than that it is copying rest of the recent config changes.
Can anyone help me out how to fix this problem. Is it a known bug. If so , can I execute this command to the secondary PIX directly.
My IOS version is
Cisco PIX Security Appliance Software Version 7.2(1)
Cheers,
Siva
stanleyb Mon, 02/23/2009 - 20:11
Hey maybe..
Well, can you please post sh failover output? You might have some other issues.
sivakumar.ks Mon, 02/23/2009 - 20:25
Here is the show failover output...
svhm-pix# sh failover
Failover On
Cable status: Normal
Failover unit Secondary
Failover LAN Interface: N/A - Serial-based failover enabled
Unit Poll frequency 6 seconds, holdtime 18 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 9 of 250 maximum
failover replication http
Version: Ours 7.2(1), Mate 7.2(1)
Last Failover at: 09:12:50 AEST Feb 22 2009
This host: Secondary - Active
Active time: 45544392 (sec)
Interface outside (0.0.0.0): Normal
Interface inside (0.0.0.0): Normal
Interface dmz-svhm (0.0.0.0): Link Down (Waiting)
Interface dmz-remote (0.0.0.0): Normal (Waiting)
Interface dmz-vpn-internal (0.0.0.0): Link Down (Waiting)
Interface dmz-vpn-external (0.0.0.0): Normal
Interface dmz-unimelb (0.0.0.0): Normal
Interface HealthSmart (0.0.0.0): Normal (Waiting)
Interface RVEEH-Network (0.0.0.0): Normal
Other host: Primary - Standby Ready
Active time: 426 (sec)
Stateful Failover Logical Update Statistics
Link : failover Ethernet7 (up)
Stateful Obj xmit xerr rcv rerr
General 4514681071 0 515801583 17442707
sys cmd 7558147 0 7558121 1
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 3166567303 0 441149517 11257278
UDP conn 1290642575 0 58911176 6185292
ARP tbl 49805761 0 8179969 136
Xlate_Timeout 0 0 0 0
VPN IKE upd 11222 0 1164 0
VPN IPSEC upd 96063 0 1636 0
VPN CTCP upd 0 0 0 0
VPN SDI upd 0 0 0 0
VPN DHCP upd 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 25 538002965
Xmit Q: 0 9 4640587425
svhm-pix#
