AnyConnect on VIsta x64 Ultimate
Feb 23rd, 2009
Hi All,
Somehow my AnyConnect client has stoped working on Vista x64 Ultimate. It works fine on any other system (XP, Vista Home, Vist Business, etc.) I'm using version 2.3.0254
I get this message when I try to connect.
The VPN client was unable to successfully verify the IP forwarding table modifications. A VPN connection will not be established.
Alex
auraza Fri, 02/27/2009 - 09:50
Please make sure UAC is disabled on Vista. Also, is there any other software you may have installed on the box that might be disallowing the box from modifying the routing table. Some Internet Security software, or maybe you're using a Broadband card?
