How to access MSFC in 6509 Switch
Answered Question
Feb 23rd, 2009
We have a 6509 switch with Sup-II module. Just wondering how I can login to the MSFC and configure routing
Please help
Correct Answer by Yudong Wu about 8 years 2 months ago
If it is in native mode, you are in RP(MSFC) now. If you want to log into SP, you can try "remote login switch"
Correct Answer by adamclarkuk_2 about 8 years 2 months ago
The you dont need to access the MSFC, your on it. Config your routing from global configuration mode.
So for ospf do:
Core_1#conf t
Core_1(config)# router ospf 1
Core_1(config-router)# blah
Overall Rating: 4 (2 ratings)
Giuseppe Larosa Mon, 02/23/2009 - 08:10
  • Hall of Fame,
    Founding Member
Hello Chandhrasekar,
Sup II and MSFC talk via internal trunk 15/1
you need
session 15
from supervisor prompt to access the MSFC
Hope to help
Giuseppe
csaravanan-sym Mon, 02/23/2009 - 08:29
Hello Giuseppe,
I tried Session Slot 15 as well as Session 15 both did not work. It did not let me in the Router (MSFC)
adamclarkuk_2 Mon, 02/23/2009 - 08:36
  • Silver, 250 points or more
My be a silly question but are you running in native mode, ie IOS on the SP and RP and RP takes control.
What prompt do you have
Type show version at your current prompt and paste the first few lines in here
csaravanan-sym Mon, 02/23/2009 - 08:42
I am running in native mode. Here are the few lines from sh ver output
Core_1#sh ver
IOS (tm) s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 18-Sep-06 23:32 by tinhuang
Image text-base: 0x40101040, data-base: 0x42D90000
Correct Answer
adamclarkuk_2 Mon, 02/23/2009 - 08:44
So for ospf do:
Core_1#conf t
Correct Answer
Yudong Wu Mon, 02/23/2009 - 08:45
  • Gold, 750 points or more
Yudong Wu Mon, 02/23/2009 - 08:41
1, "show module" to check if MSFC is up and in OK status.
2, "show port 15/1" to make sure port 15/1 is not in err-disable status.
If both is OK, you might disable your vty session in your MSFC configuration. (Session 15 command will try to telnet to MSFC).
So you might have to use "switch console" command when you CONSOLE into the switch.
csaravanan-sym Mon, 02/23/2009 - 08:44
sh module results shows the MSFC status as OK.
Sh port 15/1 throws error.
I believe it throws error, as I am running in Native Mode (Cisco IOS)
Yudong Wu Mon, 02/23/2009 - 08:46
Yeah, that's CatOS command since I thought you are in hybrid mode. :)
If it is native mode, you are already in MSFC.
