WCCP works locally, not remotely?
Feb 23rd, 2009
I've got some WCCP issues that don't seem to make sense. I've got a 7609 with a FWSM in it, and WCCPv2 enabled. I've also got a Content Engine directly connected, and it has the 7609 in router-list 1. I have the Content Engine set up to use an external Websense server, with client IP spoofing enabled. If I put "ip wccp web-cache redirect in" and "ip wccp 95 redirect out" on the outside Vlan interface from the FWSM, everything works just as I would expect... traffic gets filtered based on the IP address of the Vlan interface. If I add another router's IP to router-list 1, however, web traffic seems to die. A "show ip wccp" shows that it's connected to the content engine, but I never get a response for any standard http requests.
Routers 1 and 2 are configured like this:
ip wccp version 2
ip wccp web-cache
ip wccp 95
interface VlanX
The content engine is configured like this:
wccp router-list 1 ro.ut.er.1 ro.ut.er.2
wccp port-list 1 80
wccp web-cache router-list-num 1
wccp service-number 95 router-list-num 1 port-list-num 1 application cache hash-source-ip match-source-port
wccp version 2
wccp spoof-client-ip enable
I'm not using the L2-redirect option, so I'm not entirely sure why it's not working. In the above scenario, traffic from the Vlan on router 1 works, and doesn't work on router 2. The only difference I can see is that the content engine is connected to a GigE port on Router 1. Any thoughts?
