SPA9X2 LDAP advanced settings
Feb 23rd, 2009
  • Bronze, 100 points or more
now we testing LDAP connection, every works fine only i have one question. In AD i have IP Phone number, Mobile and Home.
i use this string
"a=cn;a=ipPhone,n=Pevna,t=p;a=mobile,n=Mobilni,t=p;a=homePhone,n=Soukrome,t=p;"
But how i can dial Mobile? everytime phone dialing ipPhone and i havent chance change dialed number
Thank you
Tomas
Patrick Born Mon, 02/23/2009 - 15:12
  • Cisco Employee,
Hi Tomas,
This is a limitation of the current LDAP functionality in the SPA phones. Currently only the first defined t=p device is used.
The only work-around I can suggest is:
Multiple entries per user, something along the lines of so the user can select which contact method they wish to use and select an appropriate entry:
     Patrick Born [mobile]
     Patrick Born [office]
     Patrick Born [home]
I have shared your information with the phone's product manager for feature enhancement.
Patrick
