PIX failover
Feb 23rd, 2009
we are using pix 5151e 7.2 (3) version and we configured the statefull failover between two pIX 515E
and its working fine but my query is when i give command sh failover it showing only the primary unit IP all interface but not the secondary unit
please refer the below sh command for ur refernce
Failover On
Cable status: Normal
Failover unit Primary
Failover LAN Interface: N/A - Serial-based failover enabled
Unit Poll frequency 3 seconds, holdtime 9 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 3 of 250 maximum
Version: Ours 7.2(3), Mate 7.2(3)
Last Failover at: 23:34:03 UTC Feb 23 2009
This host: Primary - Active
Active time: 1371 (sec)
Interface outside (x.x.119.179): Normal (Waiting)
Interface inside (x.195.21.2): Normal (Waiting)
Interface inside2 (10.195.1.254): Normal (Waiting)
Other host: Secondary - Standby Ready
Active time: 0 (sec)
Interface outside (0.0.0.0): Normal (Waiting)
Interface inside (0.0.0.0): Normal (Waiting)
Interface inside2 (0.0.0.0): Normal (Waiting)
Stateful Failover Logical Update Statistics
Link : STATE Ethernet3 (up)
Stateful Obj xmit xerr rcv rerr
General 4100 0 168 0
sys cmd 168 0 168 0
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 615 0 0 0
UDP conn 67 0 0 0
ARP tbl 3246 0 0 0
Xlate_Timeout 0 0 0 0
VPN IKE upd 3 0 0 0
VPN IPSEC upd 3 0 0 0
VPN CTCP upd 0 0 0 0
VPN SDI upd 0 0 0 0
VPN DHCP upd 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 4 588
Xmit Q: 0 8 9774
stanleyb Mon, 02/23/2009 - 20:05
(Waiting) suggest hello not received so Failover Monitoring Has Not Begun.
This happens when failover has not started to monitor the network interfaces. Failover does not start to monitor the network interfaces until it has heard the second "hello" packet from the other unit on that interface. This takes about 30 seconds. If the unit is attached to a network switch that runs Spanning Tree Protocol (STP), this takes twice the "forward delay" time configured in the switch (typically configured as 15 seconds), plus this 30 second delay. This is because at PIX bootup and immediately following a failover event, the network switch detects a temporary bridge loop. Upon detection of this loop, it stops forwarding packets on these interfaces for the "forward delay" time. It then enters the "listen" mode for an additional "forward delay" time, during which time the switch listens for bridge loops but not forwarding traffic (and thus not forwarding failover "hello" packets). After twice the forward delay time (30 seconds), traffic resumes flowing. Each PIX remains in "waiting" mode until it hears 30 seconds worth of "hello" packets from the other unit. During the time the PIX is passing traffic, it does not fail the other unit based on not hearing the "hello" packets. All other failover monitoring still occurs (that is, Power, Interface Loss of Link, and Failover Cable "hello").
Cisco strongly recommends that customers enable portfast on all switch ports that connect to PIX interfaces. In addition, channeling and trunking need to be disabled on these ports. Thus, if the interface of the PIX goes down during failover, the switch does not have to wait 30 seconds while the port transitions from a listening to learning to forwarding state.
Try and apply your commands again:
On the primary PIX, configure these commands:
ip address stateful-fo x.x.x.1 255.255.255.0
interface ethernetX 100full
failover ip address stateful-fo x.x.x.2
failover link stateful-fo
On the secondary PIX, configure this:
ip address stateful-fo x.x.x.2 255.255.255.0
nameif ethernetX stateful-fo security30
check the switch/cables in between.
reload.. ;-)
hope that helped.
vinoth.kumar Tue, 02/24/2009 - 05:14
thanks for your reply
but the failover is working fine when i switch off the primary unit but in our existing network we setup the failover with version 6.3 i have given the command # failover ip outside xxxx xxxx and also when i give #show failover it shows all primary interface IP and all secondary interface ip
PIX Version 7.2(3)
interface Ethernet0
nameif outside
security-level 0
ip address x.x.x19.179 255.255.255.248
interface Ethernet1
nameif inside
security-level 100
ip address 10.x.21.2 255.255.255.0
interface Ethernet2
nameif inside2
security-level 80
ip address 10.x.1.254 255.255.255.0
interface Ethernet3
description STATE Failover Interface
speed 100
duplex full
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
failover
failover polltime unit 3 holdtime 9
failover link STATE Ethernet3
failover interface ip STATE 172.16.35.1 255.255.255.0 standby 172.16.35.2
in 7.2 it shows only primary unit ip and statefull interface ip
i dont know its normal or i need to do some other config
