1 compact flash partition on Detector or Guard
Feb 23rd, 2009
Hello
There is 1 compact flash in the Detector or Guard module to save Activity log and Attack report.
I would like to know structure of 1 CF on G&D,
There are three data on G&D, configuration and log, attack-report.
Configuration, log, attack-report is saved in 1 CF memory? if so. could you tell me the each partition size, for example configuration is allocated 100Mbytes, and log is assigned 50M like so,
I appreciate it if you give me the answer as soon as possible.
Thank you.
