Crypto Error - %CRYPTO-4-RECVD_PKT_MAC_ERR (x1):
Feb 23rd, 2009
Hi Network Folks,
Please help me here, searching for your help.Here is the scenrio.
We have IPSEC over GRE tunnel between End A to End B.
I am receiving continious error in End A router - 2821.
Pls find the below logs.
Feb 24 01:32:43 UTC: %CRYPTO-4-RECVD_PKT_MAC_ERR: decrypt: mac verify failed for connection id=3002 local=1.1.1.1 remote=2.2.2.2 spi=A787F8E5 seqno=00000174
I have tried rebuild the tunnel at both the end but no luck, can anybody suggest for the above errors.Awaiting anxiously
Ivan Martinon Tue, 02/24/2009 - 12:00
On the router that logs these messages, can you increase the replay window size?
kdelhi_ganesh Sun, 03/01/2009 - 12:03
Sorry for the delayed reply;Infact there is no production issue because of this errors.
Thank you all for replying me for the above issue, i got the advice from TAC saying " THIS IS THE KNOW ISSUE AND NEED TO DOWNGRADE THE IOS"
Ganesh
auraza Thu, 02/26/2009 - 13:46
This error basically means that the packet failed authentication.
You can try disabling the hardware crypto engine and see if that makes the error go away:
no crypto engine accelerator
If the error doesn't go away and it changes to a different error, it could mean that packets are getting corrupted in transit, and thus failing authentication.
kdelhi_ganesh Sun, 03/01/2009 - 12:02
Ganesh
