Backup Interface + track?
Feb 23rd, 2009
We have setup failover for WAN connections via the backup interface command(Eth->ATM(Dialer)) - This requires the eth interface to be physically down before the ATM/Dialer is bought up.
Is there a way to use object tracking in conjunction with the backup interface command?(As the Ethernet Int "rarely" physically goes down, but can lose ip connectivity)
Reason for not using object tracking/verify-availability only: Service has an additional subnet routed to it, advertised via OSPF on Eth Int, and dynamically routed via radius once the dialer int comes up.
Thanks in advance.
