Richard Burts Mon, 02/23/2009 - 20:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
vinoth
The main advantage of stacking is that you get to take several individual switches and configure them and treat them as a single entity instead of as several independent individuals..
Also, depending on the particular switches and their stacking technology, you may have a switch to switch connection at much higher throughput than the capacity of an access port (or trunk port) connection between switches.
Rick
e.claveau Tue, 02/24/2009 - 04:47
You also have the advantage of using a cross stack LACP etherchannel for redundancy instead of relying on spanning tree when using a stack as a distribution layer switch or as a server access layer switch.
Joseph W. Doherty Tue, 02/24/2009 - 05:46
The "stacking" the other posters have noted usually uses a special dedicated stack port. Cisco's 3750 and 3750-E series Stackwise/Stackwise+ is an example, see http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_presentation09186a0080161372.pdf for more information.
An earlier version of Cisco "stacking" technology was GigaStack, see http://www.cisco.com/en/US/products/hw/modules/ps872/products_data_sheet09186a00800a1789.html or http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/installation/guide/mamoint.html.
However, I've also noticed "stacking" is sometimes used for a set of switches, often in a rack, that "daisy chain" or "cascade" port connections from one to the next. In this configuration, each switch is configured independently (unless perhaps switch "clustering" is supported). Such a configuration uses less ports than a "star" configuration.
