ASA, SMTP, telnet test
Feb 23rd, 2009
access-list incoming extended permit tcp any host 7.17.20.9 eq smtp
static (inside,outside) tcp interface smtp 10.1.40.5 smtp netmask 255.255.255.255
Have the above lines in an ASA. Yet when I try to test if port 25 is open by doing "telnet 7.17.20.9 25" i get connection refused.
Now, for some reason I seem to remember this being normal behavior for an ASA or PIX. Something to do with the "fixup" idea from a PIX? I never quite understood that.
Could someone tell me if I should be able to telnet to port 25 on that IP address using an ASA? I know you should be able to with, say, a SonicWall.
