vpn client issu
Feb 23rd, 2009
Hi, I have asa 5505 at one side and I am connecting thru cisco vpn client.
fine I got connected ok and getting ip from dhcp(asa) fine, but unable to ping or access any services from remote lan.
eddie.mitchell@... Tue, 02/24/2009 - 08:00
  • Silver, 250 points or more
Are you using split-tunneling or non-split? Is your VPN client receiving the appropriate routes? Are you using the 'sysopt connection permit-vpn' command on the ASA?
blue4cisco Tue, 02/24/2009 - 21:59
I tried in both split n non-spit mode no gain
below is setup
asa-----Internet----adsl(nat)---office(lan)
pls. see attached snap
eddie.mitchell@... Thu, 02/26/2009 - 04:56
Do you have 'management-access inside' in your config? If not, I would try adding this in global config mode and re-test the ASDM connection through the VPN tunnel.
blue4cisco Fri, 02/27/2009 - 01:25
well issue is not whether I am able to access ASDM or not. I was accessing just to confirm as to end to end connectivity is working or not.
auraza Fri, 02/27/2009 - 05:36
  • Cisco Employee,
Make sure the following is set up correctly:
1) NAT exemption
2) Internal devices routing to the VPN Client pool, through the ASA, if ASA is not the default gateway
